So, is it GM or HPtuners that has it labeled wrong, that Map B(Winter) should be Map C?
Also, is there another table involved when I select Rain/Snow mode? Possibly on tcm side?
It's hp tuners.
on the non performance cars it was most likely like it is labeled.
you can easily check which mode it is running in, there is a PID for it'S rather "drive mode requested" or "accelerator pedal mode"
ok, thanks for your help...Do you think any other table in applied, perhaps on trans side i need to look at as well? Basically i am trying to help with traction issues. I am 900+hp and was thinking i can put it in Rain/Snow mode to see if it helps some. I was gonna start with a 20% reduction compared to the other tables and adjust from there up or down depending how it does.
in general I could... but only if I wanted to share my proprietary knowledge I built over years. ;)
but i suppose their engineers are smart enough to find those tables on there own if they want.
I already shared some important tables for the ATS-V community which are now commonly available.
regarding benf's question, what happens in the transmission or EBCM is on a differnt board, but surely they also have individual strategiers for the different modes.
what probably helps with traction would be to reduce minimal spark, so the TCS maybe can pull out more spark, but watch you egts then!
i did something similar on my old LHU, there TCS always involved predicted request..so throttle cut, I switched that to immediate request and played with min ign, which lead to freaking fast TCS right at the slip limit, but of course through ignition retard/cut you could see EGTs going up in TCS event.
but not sure if the newer OSs have this switch too.
sure they do, please don't take my last post insulting or arrogant.
i am just trying to give information, as english isn't my mother tongue this maybe sometimes "sounds" not as expected.
if anybody wants to use that, he can ask HPT team to include the maps. or if anybody is intersted, he can write me a pm and i most likely can tell you the adresses, so you can add it yourself with user defined parameters.
This is why it is confusing cause mine shows it this way
dertobi, its all good :cool:
benf, everyone's looks like that. But the labels are wrong for Camaros and Corvettes at least. Map B is Track Mode.
