Originally Posted by
DarrylC
Just a bit of an extract from the Territory Workshop manual:
U 1900 - CAN Communication Bus Fault, all errors refer to CAN communications and I guess there is no CAN bus in your case
U 2514 - Damaged wiring or connection between the VSS and PCM. Error on the SCP system between VSS, PCM, IC and DLS Incorrect VID programmed in to PCM. PCM, IC, ABS not running current software and calibrations.
Go onto the Australian Ford Forums and find the link for the workshop manual, very handy. I have had the U1900 error when a connector under the large connector box under the bonnet had a connector come loose.
Hope this helps.
