Originally Posted by
Higgs Boson
Going from memory,
For the cams, the path starts on the lower right side with the Desired Air Load tables. Basically, they will tell the ECM how much you are pushing the gas and choose Stability, Economy, or Driveability (or Optimum Power).
Next, the Distance tables will look at RPM and load and decide which Distance Point to use. Now for all of them except for Driveability, the Distance Points reference another table just above those that relate the Distance Point to a Mapped Point in the IVO and ECV MP tables in that same area.
Driveability, as best I can tell, Distance Points related directly to the Mapped Point cam angle tables.
Now you can follow the path from Air Load to Distance Point to Cam Angle.
I have been playing with different settings and ended up enabling Optimum Power (2016, should already work on 11-14s), and editing the Air Load tables to suit my preferences. I ended up leaving the Distance Point and Mapped Point tables stock because changing those gave me misfire codes since now the spark tables would be wrong.....I don't have time to reinvent Ford's wheel on this VVT/Spark relationship so it can just stay stock (with stock cams) and Optimum Power tables can handle all the WOT/heavy throttle stuff just fine.
With aftermarket cams I suppose it would take a lot of work to fine tune the part throttle stuff, but I wouldn't really see an issue leaving it stock as long as the cams were installed like the stock cams, obviously with more duration and maybe lift....use Optimum power tables to handle overlap amount and location just the same.
With locked cams however, I would think you just disable the VVT system entirely with the drop down box and mapped points would not even be a factor.
