Attachment 95886
Attachment 95887
08 ls3 vette with 6l90 is wanting to takeoff from 4th gear when tuning ve. I have attached the file and log if anyone sees anything to help me out with this problem.
Thanks!
Attachment 95886
Attachment 95887
Thanks!
I have had this in the past, i forget exactly what caused it, I do know it is in the ecm torque management tab that it is happening. I would go back to a file that is known good, then load your settings back one at a time, till you hit it. Its cumbersome, but its easy to tell if its fixed or not, if your logging commanded gear, it shows 4 as soon as placed in drive
This worked! Needed around with some torque mgmt settings and set P0101 to no error reported. Not sure which one did it but I can now start in first gear!
