A whole slew of problems...
Here's the setup:
2000 Chevy Cavalier Z24 (2.4 LD9) manual transmission with the GM supercharger reflash. However, the reflash is from another 2000 Chevy Cavalier Z24 with a manual transmission. Our VIN numbers match up except for the last 5 digits. To get the car licensed properly, I purchased the entire 2000 Chevy Cavalier license due to the fact that I have three other 2k cavs running around that need to eventually be tuned.
HP Tuners 2.1.10
MVPI Pro running version 108
Problem 1:
Under the menu Flash, Change VIN does not work or maybe I'm not doing it correctly. Here's the error I get:
http://www.emulsified.net/upload/pics/hpprob.jpg
Problem 2:
Writing my calibration AS WELL AS writing everything produces this problem:
http://www.emulsified.net/upload/pics/hpprob2.jpg
Problem 3:
Doing a non-active test write of the calibration AS WELL AS writing everything produces this problem:
http://www.emulsified.net/upload/pics/hpprob3.jpg
Here's the explosion of information that's produced from the error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ac.?()
at ac.?()
at ac.?(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
Assembly Version: 2.1.10.0
Win32 Version: 2.1.10.0
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/VCM%20Editor.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
C1.Win.C1FlexGrid
Assembly Version: 2.5.20053.220
Win32 Version: 2.5.20053.224
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1FlexGrid.DLL
C1.Common
Assembly Version: 1.0.20031.116
Win32 Version: 1.0.20042.118
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Common.DLL
C1.Win.C1Chart
Assembly Version: 1.0.20053.15236
Win32 Version: 1.0.20053.15236
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart.DLL
C1.Win.C1Chart3D
CodeBase: file:///C:/Program%20Files/HP%20Tuners/VCM%20Suite%202/C1.Win.C1Chart3D.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Problem 4:
Changing the VIN number from the calibration details window produces the following error:
http://www.emulsified.net/upload/pics/hpprob4.jpg
What the hell is going on? Is this a result of having the ecu program of my buddy's reflashed car on my car? Do the BCM VIN and ECU VIN absolutely have to be the same? If I recall correctly in the HP Tuners help file as well as everything else on this forum and any other technical document I've come across, nowhere does it state that the VIN on the ECU and the VIN on the BCM need to be identical. It just says that the OS must be compatible with the ECU....which it is since my car has been running tip top with the reflash since day one.
Any help from anyone would be excellent. I'm currently dead in the water with this.
