1 Attachment(s)
Wideband serial to usb disappears when scanning
Hey guys so I have set up a channel in my channel configuration for an AEM 30-0300 wideband gauge. This channel is set up so that I can use the gauges serial cable capability, I use a serial to USB which is plugged into my laptop.
The issue that occurs is whenever I hit start scanning, the entire channel disappears and I cannot get it back until I close HPTuners out completely. I am certain that my drivers are good as my cable is showing up when connected. I believe I have the proper set up but I could have messed something up, I will leave the channel down below so that anyone can double check. Edit: I want to let it be known I am not on the Pro edition
Mods if you delete my previous thread in a different sub section it would not upset me.
Thanks guys
Attachment 112429
