1 Attachment(s)
Not shifting fast enough?
2013 Dodge Challenger RT - A5
Heads, cam, long tubes, catless mids, 3" exhaust, Whipple
A5 trans, 3000 stall converter, 3.92 gears
I've never had an issue with shifting but I've been tuning by doing 3rd gear pulls. I finally got to where I have been running it out to the shift points at 6300 and it is not shifting well. I believe the car used to do this in 1st gear at the track where it felt as though it's flying up in RPMs so quickly that the car cannot shift fast enough? I am not sure.
I have all the torque management turned on in the trans and the only thing not set to stock in the TCM are the shift points and the TCM RPM limit. WOT shift is set to 6300 and the TCM RPM limit is set to 800 with the limp offset at 500 rpms.
I do have some torque management settings turned off under the PCM. I am going to turn the auto trans torque adapts back on to see if that helps but does anyone have any ideas?
Here is a scan showing what is happening. This car pulls like a raped ape so hopefully it's something simple that I'm overlooking.
Attachment 68979
8 Attachment(s)
NAG1 / WA580 Shifting Too High & Too Slow
I'm having the same issue with my 2012 Dodge Charger SE 3.6L with NAG1, supercharged and tuned by RIPP. Ever since I swapped my gears from 2.65 to 3.06 my shift points at WOT are consistently 1-2 @ 6550 RPM and 2-3 @ 6450 RPM (6,400 is redline for Pentastar 3.6L) I'm afraid that will damage my engine internals. I did change the gear ratio in the Cluster tab and did the NAG1 Init. via HPD Tuners VCM. Prior to swapping 2.65 gears to 3.06 my shift points at WOT were at about 6100 RPM 1-2 and 6250 RPM 2-3, which was totally acceptable. My current TCM settings are as follows: TCM RPM Limit 6400 RPM, Limp Offset 500 RPM. Auto Shift Speed/WOT/Normal/Upshift: 1-2 1611, 2-3 2739, 3-4 4255 and 4-5 6000 (target 6000 RPM shift in every gear), WOT>Enable, Enable Pedal>98%, Autostick/Auto Upshift>Disable, Autostock WOT>Enabled, Shift Time/Max Shift Time>2800ms. In ECM/Fuel settings: Cutoff/DFCO/Maximum RPM is 6800 (don't know why RIPP tuner set it that high). I know there is a normal delay 200-250 RPM between the shifts but my shifts are extremely slow and I redline every time with WOT. A few times it bounced off rev limiter in 1st before it shifted to 2nd. Also, I'm not sure if that's a contributing factor but the Sport Mode has been enabled via Z-Automotive TranZformer. I like 2500-3000 RPM shifts while coasting. I attached some screenshots, .hpl and .hpt files for TCM and ECM. I don't know what I'm missing here, maybe someone could help me out. I'm pushing 420 BWHP and certainly don't want to be anywhere near redline. I'm looking for consistent 6000-6200 RPM shifts. Thanks in advance!
Attachment 70197Attachment 70198Attachment 70199Attachment 70200Attachment 70201
