2 Attachment(s)
Tune gets a bug and no longer works anyone else?
iv had this problem ever since I started tuning my 5.0. its a 2012 saleen supercharged, problem I have is for no reason ill have a perfectly working tune and then will get a bug on the very next flash. sometimes it will be as simple as adjusting fuel maf period and it will cause a the timing tables to use map points 1-9 when wot and at 6000 rpm it will jump to OP table , also car will develop a die returning to idle issue. or worst case a no start after just adjusting fuel. have checked battery when uploading always at 13v, firmware is updated. I have tried making a support ticket with no luck.
