'04 F250 Speedometer Correction
Anyone had any luck getting the speedometer (along with the broadcast VSS PID in the scanner) corrected for tire size? I've tried correcting every parameter for the given tire size that is found in the ECM and TCM.
Truck has 3.83 gears, and 38" tires.
Speedometer parameters set as follows:
Use VID = Disabled
Final Drive Ratio = 3.83
VSS Tire revs per mile = 530.74
N/V Base = 32.7965
N/V Min Learned = 32.0000
N/V Multiplier = 10
Even changing the N/V drastically seems to make no difference to the error between actual vs indicated.
Any help would be greatly appreciated!
