1 Attachment(s)
01 5.3 Silverado 1500 poor acceleration/no power
Hey guys looking for some input: This vehicle is on a stock tune, I wanted to get this somewhat running ok before I attempted to tune it.
2001 Silverado 5.3. starts and seems to run fine at idle when I step on the gas it is very sluggish off the line and struggles to go anywhere. It just Boggs and acts like it has no power.
I have checked Fuel pressure and it is steady at 58/59 psi.
Cleaned out the MAF.
New plugs
cleaned the throttle body.
Checked for vacuum leaks.
Was curious if anyone noticed anything out of the ordinary with my VCM log. I am still a newbie, and my experience is limited using the VCM suite.
stock bottom end
Pro LS Cam 232/242 113+3 600/600 Lift
roller rocker arms from a ls1
ls rocker arm bolts
hardened push rods
(Other wise stock 862 heads)
stock air intake manifold
Torque converter
ACC performance 49454 3200-3600
*****List of codes that I have gotten for the VCM scanner*****
P0101 - Mass or Volume Air Flow A Circuit Range/Performance (Pending)
P0135 - O2 Heater Circuit (Bank 1, Sensor 1) (Pending)
P0155 - O2 Heater Circuit (Bank 2, Sensor 1) (Pending)
P0342 - Camshaft Position Sensor A Circuit Low (Bank 1 or single sensor) (Pending)
Controller Type ID By VIN: 5070
Controller Type ID By OS: 5070
