E85 with Flex Fuel and Sensor-less Tune
Hi All,
I've enabled Flex Fuel with Sensor-less to see how the F-Type works with varying amounts of Ethanol content. I was hoping it would provide a calculated value for 'Ethanol Fuel %' but it doesn't.
So, I'll just have to watch the knock and fuel trims to see how it performs without knowing the exact Ethanol %.
The initial test will be with 93 and no additional E-85.
I'm also changing the Secondary Fuel value to 12.8 which would be around E30 as I'm going to add around 5 gallons to the 93 octane.
So if any of you have tried it, I would like to know your results.
