1 Attachment(s)
New Swap! Need help on what else I need to do before first start?
Hello,
I'll start with what i'm working with
2003 S10 W/p59 computer / Current performance Integrated Wiring harness / No emissions / Linginfelter converter box
2012 5.3 Block
99 5.7 heads
LS1 Intake
04 Z06 cam, lifters and springs
04 vette MAF
92mm TB
Stainless works long tube headers
I did a compare files and copied the VE, spark and MAF data from a 04 Z06 stock tune and any other data that seemed relevant to the engine parameters.
I don't have an IAT sensor. Or is it part of the MAF? If not Is that going to be a problem? or can I disable this sensor?
I have did the COT disable, and no error report and ses for the rear O2's
I also did no error report for all things that showed evap or egr
Also I have the older style knock sensors installed on the side of the block instead of under the intake. Do I have to do anything special for that?
I think I got everything (I'm sure I'm way off) Or maybe I'm completely going about this the wrong way. I'm new to this and I've been doing ALOT of reading on here and just not sure what else I may need to set up before getting it started
Any help would be appreciated.
I attached my tune for any advise. Be gentle, I'm new! :cool:
Thanx,
Cory
