1 Attachment(s)
03 LB7 New Tuning help
Stock LB7 File. PPE valve, Turbo resonator delete, CAI, and 3.5 inch straight pipe.
New to diesel tuning, fairly new to tuning in general. I have done some research and am thinking about attacking my tune file. I have downloaded a few files to use as compare files, looking at the differences. forums suggest tuning certain areas while most files i downloaded are modified in other areas unmentioned.
I will attach my stock file, could someone please make a transmission safe tune with a little more performance over stock. i do not tow anything. I will use the file to run my truck, but also use it to reflect on research as a compare/contrast learning style. Thanks so much.
77 HP Tune
Have you seen this one?
It was posted sometime ago (I can find the thread otherwise I give the OP credit)...
It's a mello tune given to a guy to see what a difference just a little adjustments made in performance...
Then as you asked compare it to stock and manipulate from there...
I have not personally run it, but compared to a stock file it seems perfectly safe
