Golf 2.0t
Can somone please upload an original file of a golf 5 gti or 6
And as for those ecu they are torque based ecu so to boost up we should change the torque demand and push all the pressure tables by 10% or more. I usually tune naturally aspirated but I'm trying to get into these turbo charged cars thank you in advance
I don't know much about tuning Golfs, but there's an easy way to tell if the engine-management is torque-based or not: open the hood and look at the throttle body. If it's mechanical (operated by a cable), the engine-management system is not torque-based. If the TB is electronic, it's 95% likely it's a torque-based system.
yes thats not my problem i know this but i want to see if someone can send a sample that i can see or see the results and what limitation or what is the maximum possible on this engine. ANW thank you on the info
