I1 have a Gen 5 LT1. When using VM Scanner the oil pressure will not display when the motor is running. I have T'd in a gauge and know there is oil pressure. If I remove the sensor and manually apply pressure and the display works if the motor is not running. As soon as I start the motor the oil pressure display stops working. All other parts of the display work all the time. The oil pressure voltage is present at the input to the ECM all the time. Any ideas?
