I have done the typical windows reboot, and no change.
You'll need you to send your debug.dat file (located in Documents\HP Tuners\Settings) to [email protected] and we'll look into this issue.
Thanks,
Matt
Matt I noticed a bug with this as well... I've had to click disconnect vehicle and reconnect multiple times to get the values i have saved to show up and log... sometimes that works. Sometimes i have to disconnect the vehicle, and click start scanning which then pulls it up.
Should i get the debug log for you as well?
The other thing that helps is installing the newest version of 2.25 every day... they come out with so many new releases...
So, what kind of response time should we expect from support@(considering that the software is still "beta")? I'm not expecting an immediate fix, but an acknowledgement that someone is looking into it would be nice.
Pilot Inj Timing
Post Fuel Rate
Post Inj Timing
Pilot Timing Correction Reason
Post Timing Correction Reason
Main Timing Correction Reason
Protection Factor Reason
Post Fuel Correction Reason
Pilot Fuel Correction Reason
Fuel Pressure Correction Reason
Torque Control Correction Reason
Air Density Table A
Air Density Table B
Are all of these PIDs available to all years? I have an early 04 with the cm848 and I can only bring up the following from that list:
Pilot Inj Timing
Post Fuel Rate
Post Inj Timing
I have tried pulling a new stock file, apply the patch, and then reload it. Doing that didn't change anything, still just those same 4 PIDs. I also tried deleting all of the vehicles in the scanner folder as was mentioned earlier and that didn't change anything either. The rest of those correction reasons would be really nice to have.
I'm using the latest 3.0.37 and have lost parameters in my logging. I have applied the OS patch but still can't get them. They are greyed out in my log, For instance I can no longer log pilot or post timing. I can still log pilot and post duration though
Try hitting "Repoll For Supported Parameters" in the Vehicle menu.
-Matt
I am new to HP Tuners. I have a 05 and i was wondering why HP does not show the boost with the right values? It shows boost but its way off at an idle it shows me having 12 Psi boost. On a side note my other question is how do you use your logs to fix your tuning? I was told there is a way where it gives you tuning suggestions.
Your boost value includes atmospheric. So your boost at your elevation you need subtract 12psi from recorded value to get your actual boost.
I don't know where you heard that the scanner gave tuning recommendations but it is not true.
I can't seem to get the patch to apply
The additional PID'S don't show up after deleting vehicle data file and repolling vehicle. Just installed 3.0.44.
