Will the Dodge release that is coming soon support the V8 Magnum engines?
His Durango uses a JTEC PCM not a NGC3. But it seems that JTEC will be supported too. I hope it at least. :pray:
I should have read closer, I assumed the Magnum = the LX wagon not the Magnum engine.
My bad.
Keith has a Viper so yes the JTEC will be supported soon after... ;)
NGC3 will be first, then JTEC.
Do you have any kind of rough time frame?
A month, 2 months, 6 months??
Can you tell me if the NSRT4 will be supported up front as well? I believe it has the NGC3 as well.
I understand. :)
I'm just glad to not be in the dark so much!
Thanks for the update.
I think (hope) this means that Keith and the crew have a good reason to come up with a proper way to run boost with the JTEC :burnout:
- Chris
www.dcperformance.com
if you can convince Keith to put FI on it then yeah, maybe... BIG maybe.
Rofl
Back on topic .... :banghead:
This stuff will be out next week? :D
