Please help, this is driving me crazy lol. Gen3 LS1 btr stage 3 cam. LSA supercharger, NW102 throttle body. Manual trans
When I start RPM goes high then dips low. Log and tune postedAttachment 92488Attachment 92489
If it's speed density only, make sure you fail the MAF correctly.
Ok I made sure its in SD only. I am not runnig MAF. I will gladly pay for help!
Got the startup flare to not be so dramatic my increasing the Startup flare control table. still like to dip though. RAF table is correct now. Any advise? I just wanna drive without it wanting to die
I would check your timing table. I have same cam in auto and my tunes are posted on this forum. My car idles fine and at startup idle is 950 and slowly comes down to 750 per tune as it warms up at idle. In gear idle is set at 705 rpm. I am running stock air box and filter.
Steve
Post your tune file.
its posted
Not failed correctly
[attach]92596
