2 Attachment(s)
New to HP Tuners, Mystery Cam 6.0 LS1, Closed Loop Help
Hi Friends!
I'm new to HP Tuners, I've used it in the past to basically turn off VATS on stock engine LS Swaps that my shop is just starting to get into.
I have a customer's car that he thought had a bone stock 5.3, when we replaced the rear main seal we discovered it's actually a 6.0 and has some kind of mystery cam in it that isn't stock, customer has no idea what cam / specs.
The car came in with a carb, we've converted it back to EFI using a JEGS fabricated intake manifold, 102mm throttle body, an eBay wiring harness, and a PCM out of my buddy's wrecked suburban.
I'm having 2 issues that might really just be 1 issue. The car won't go into closed loop on its own, and it sometimes makes popping noises. If I command closed loop it runs significantly better.
I'm using these o2 sensors
My suspicion is that these o2 sensors are wrong, aren't working, etc. but at this point I'm just guessing and I would love some expert advice before I spend any more money.
So my questions are basically: why won't this go into closed loop? Are these o2 sensors working? if not what o2 sensors should I get?
Attachment 115409
Attachment 115410
The times in this log file that it goes into closed loop are when I manually command it through the scanner.
Thank you so much in advance for your help and advice, again I'm new to this so I apologize if I've left out any important information, please let me know what you need and I'll provide info as quickly as I can.
Happy Thanksgiving!
-Dan
