60 lb. injector minimum pulse setup LE5 SC Harrop E67 ECM
Quote:
Originally Posted by
lwrs10
updated the first post.
You referred to a minimum PW of .711 for the FIC650Bosch split spray injector, and and E67 ECM
I have installed these in my 2.4 LE5.
I am having a problem at idle, I cannot get them to adjust to Lambda 1.0 at idle...(PW 1.2-.6ms)
I am running a manifold referenced regulator with nominal fuel pressure of 43.5PSI @ ATM pressure.
My tune was spot on with the GM 42s, but it is rich now, not responding to MAF changes 3250Hz to 1000Hz...
Help...
