Is the Garmin GLO2 supported by track Addicts? I want to use this in combination to a IOS device.
While there's no direct or "enhanced" support for the GLO or GLO2, as long as it provides its location updates via the normal iOS location framework, like the original GLO does, then it should work. It will appear to the app the same as the phone's internal GPS (tricky for us to tell the difference in these cases), but typically with more frequent updates (we get 4 Hz from the original GLO), and better location data quality.
GLO2 worked fine with Android version, if that helps (I don't have any iOS devices). BUT -- before each session, you must be extra-careful to check that the external GPS device is active, not the phone's internal GPS. See: https://forum.hptuners.com/showthrea...GPS-connection
