I am curious about the Intake CAM Angle PID. You can see from the screen shots I have the desired angle to start phasing 1* around 5200RPM and step up from there to 4* per the cam vendors recommendation. This looks accurate when I go to log. However I am seeing data in the 400, 800, 4400 & 4800 RPM where it should be 0. Do I have my table setup wrong in vcm Scanner? maybe bump the hit factor up to 5? or is this normal?
Attachment 113426Attachment 113427
