Does anyone know what causes the throttle to hang WOT when letting off the throttle on a supercharged 2015 GT. It is scary when you need to cut the throttle quickly and it is slow to close.
Are you sure it's wot? Or just not closing completely?
When the car is spinning the tires and going towards the wall I am sure it close to WOT
What does datalog show?
I doubt you'll be able to get much help without posting the .hpt file & scanner log of the issue, good luck.
I will take the car out and log the issue. It is fairly common issue that multiple people have with multiple tunes. I am surprised you guys have not experienced it.
Could be tq table related, I was messing around one day and found that if DD and tq tables are too high it'll cause the TB to stick under certain conditions. For what I found; it would stick at low-speed 30-50mph and under 25% pedal input. The TB would stick open at 25* static and not close till I forced the car to stop with the brakes.
