Speedo Tab questions on Gen4
Before I just start playing with it to see what works I was curious what exactly these dropdowns do in the calibration tab under the speedo section. Of course when you hover over it gives me a description but doesn't exactly answer my question.
Under the Hardware section it has a drop down for Speed Output type with the options Wheelspd, VehSerial, and VehRepTOS. This is a swap so I do not have the wheel speed sensors hooked up at all for vehicle speed. I am assuming I would want to change this to VehRepTOS so it uses the output shaft speed for vehicle speed instead of the wheel speed sensors. Not able to find a definite answer.
Also under the Vehicle Speed Sensor section it has a drop down for Vehicle Speed Output which is disabled by default but also has a RepTOS in its drop down. I am assuming I would also need to set this to RepTOS.
and finally under the Wheel Speed Sensor section it has a drop down for Wheel Speed Output which is enabled by default. I'm guessing this also needs to be disabled.
If anyone knows what I need to set things at so the speedo will work without the wheel speed sensors that would be awesome
