Originally Posted by
HaasExp
Adding another bump with the exact same question: What is this parameter actually used for?
According to the HP tuners info bar it's the "Factor to convert from Mass to Injector PW during startup (mg/ms)". Given the units are in mg/ms you would have to assume that you set it to the same as whats in the Fuel Mass vs Inj PW table at 1ms? At a guess I would probably think that the mass defined here is used to gauge the amount of fuel wetting the runners/ports during the start up phase thus possibly affecting transient fueling during this phase.
It seems that the actual amount of fuel on start up is defined by the start up base PW x baro multi x FFV multi x closed/open throttle multi tables.
