did 122 scale work for 2 bar map
Kinda but I?m still having problems getting fuel under boost I?m leaning out
are you running open loop
The problem with dividing in half is I ended up going from 20kpa idle to 40kpa wot so not enough roof for adjustments so I?m playing with the map scale still to try to get my fuel map as large as I can without going over 105
No closed loop until I get my shit half way right
i will keep trying as well this afternoon, see what i can come up with
Iv got the scale multiplyer set to about 190 right now and it?s working out very good I could still got alittle higher in only running about 8-9psi
Once I get my tune done I?ll post it in the tune repository
awesome progress , you would have to post future tune in the forum, repository doesn't work . good work!!!
what engine set up do you have? if you don't mind sharing
2001 Jeep Wrangler 4.0 comp cam,yella terra roller rockers and magnum power supercharger kit
This is by far the most aggravating pcm iv had to mess with iv tuned many all motor and boosted LS?s and a few coyotes but this by far beets them all..your just very limited to what you can do with them and nobody knows much about them so with everything else there 1000 people that have done the same thing your doing but not with this...but that?s what makes it fun
we will get there soon
Don't forget you need to eliminate baro correction....
do you set the min and max baro to 1?
Alright thank you spoolboy will do that
put this file and check afr at idle - part throttle - wot
and tell me
Attachment 97936
Ok thank you doing it right now
Very lean
I added alittle fuel to the entire table,now I?m going to see what that does
