hey guys have an 02 sierra needing help, runnning e85 truck wont stay on unless giving it throttle.
any help or suggestions?:banghead:Attachment 101821
You sure it's got enough fuel in the MAF/VE?
You also didn't change the cylinder volume, so it still thinks it's a 4.8 engine size.
ohh yes thats true l need to make that change, ill make that change soon any other change i should make for the e85
seems to run but as soon as i let of throttle turns off.
Just like 5F said, adjust for the proper engine displacement, then you need to change the Stoich AFR to 9.8.
After that, open the throttle blade to allow additional airflow into the engine. You didn't say what TB you are running.
If it's a stock TB, you can open it up until your TPS is between 0.80- 0.82V. That'll be a great starting point.
I assumed he set the stoich to 10.50 because it's just pump E85 that is more like E70ish at a gas station.
yes e85 from gas station and throttle is an aftermarket ill look into the part#
thanks guys do need some help with this thing
throttle is a gplus cable driven not sure on the size, should be either 92mm or 102mm
ok ill give that a try
