2 Attachment(s)
2006 Mustang GT with E-Force SC Kit High Idle/Rev Hang
Hello all, I have searched high and low for a solution to this problem on this and other forums. While I have found some information that seems to be pointing me closer to an answer I have so far not found what I am looking for.
I have a customer who installed a Edelbrock E-Force sc kit (P# 15800) onto a 2006 GT 4.6 3v. Other mods are a deleted exhaust and 90mm intake/maf tube.
The tune I have arrived at provides almost perfect AFR's at idle, doing rpm steps, and under full load. Makes good power, and runs very smooth. The issue I am fighting before I deliver it do him is a persistent rev hang (while driving or just revving in neutral) and high idle. While driving and decelerating in neutral (MT) the rpms will hang at 1500 - 2000 until I come to a complete stop. At this point the rpms will settle into a lower range, but still quite high. The lowest I have seen the idle is about 950 rpm. Idle set point is stock. I am sure it is related to the single blade 85mm throttle body included in the E-Force kit, stock these use a dual blade TB.
I have not attempted any idle airflow, decel spark, or dashpot adjustments yet - I am thinking that is where I need to focus. If anyone can point me in the right direction on getting my idle set to an acceptable level (750-800 max) and removing that very annoying rev hang I would be very grateful!
Most of my experience tuning is in the standalone world - this whole "let the ECU do the work" thing is really throwing me off.
Attachment 109049Attachment 109048
