controller unlocker timer failed. No start no nothing
2004 tahoe P59 ecu. Went to change the tune just a very minor idle adjustment and when erasing I got the message "Controller Unlocker Timer Failed". Disconnected everything and turned truck on/off tried again same thing. Disconnected battery tried again same thing. Disconnected battery for longer (About 30minutes) and disconnected and reconnected blue and green ecu connectors to get the same failure again.
Battery is less than 6 month old AGM that shows 12.4volts.
Hardware and software are both up to date.
I've probably flashed 30 writes onto the truck with no issue other than it always fails boot down loader in high speed mode so I just un-check that box.
Truck won't start can't even move it out of the driveway to get my backup daily to work tomorrow.
Is my ECU bricked? If so how?
Any chance I can fix this tonight?
