Setting up NGK AFX Wideband to read Lambda
My NGK AFX is currently set up to read AFR in HP Tuners and not Lambda (MPVI2 Pro). While the NGK AFX display will only read-out in AFR, I would like HP Tuners to read and display in Lambda. Is it possible to change the NGK-AFX Function: (input/0.7142857) + 9 = Output in user defined to accurately display in Lambda? In an effort to accomplish this, I changed the function to read as follows, (Input/0.6177) + 1.0981 = Output. With this change, when the NGK AFX displayed 14.5, HP Tuners would display .75. So now it should be clear, I don't have the slightest idea of what the hell I am doing. What should I input in user defined for the NGK AFX to read in Lambda, Function: (Input/______) + ______ = Output. Looking for some help.
