Can anybody on here find a channel called turbine torque in an 8spd TCM?
About 1/3rd of the TCM tables have an axis called out as turbine torque.
Is this the same as flywheel torque for tuning purposes?
I wouldn?t think it would be the same as flywheel torque. While the TC is in direct coupling mode it would have same torque theoretically as the the flywheel, not 100% though as there is still some slippage although very very minimal. In fluid coupling mode the torque on the turbine of the TC would be vastly different from the flywheel.
Support just added it to the latest beta currently available for download 4.5.803
Connect and re-poll after installing and it should be there if anybody else needs it and doesn't have it.
