30-0334 | Loosing all data when connected except WideBand EQ
I installed the 30-0334 and the gauge displays numbers as it should. However when I plug the OBD cable (from the AFR) in and then the HP Tuner MPVI2 cable on top of that, HP Tuners only reads the WB EQ but I loose everything else. If I disconnect the AEM Gauge and plug HP Tuners cable back in, all data is back except of course the WideBand.
Not sure what I'm doing wrong here. I followed everything on the Youtube video that explains how to add the WB EQ, but as soon as I start to record I either get the WideBand or everything else depending on whether the OBD Passthru cable is plugged in.
