LT4 Swapped Nova 8L problems
So we have inherited another shops job. Lt4/8L90 installed in 66' Nova with speartech harness. The PCM and TCM were flashed by Speartech with correct OSs. The shop couldnt get the car to shift so they condemned his A8 and sent him on his way. We installed a 2018 8L (Had '19 8L90 installed) and it went through the gears fine. Fast forward 2 months and he wants a Speartech TUTD shifter, ok. Installed it yesterday. Now its as if trans is in Limp Mode. Has little to no throttle response and doesnt even seem to load up at all when put into drive. So i put VCM scanner on it, no codes, everything normal, but when i watch PRNDL status it goes Park > Rev > Neutral > Unknown 82 >Unknown 81. I have verified TUTD is enabled and this TCM is set as a '15 Vette. Do i just have a faulty shifter? Is there more setup than previously anticipated?
