Tuning Return Style Fuel for 4.6l 3V swap
Can anyone guide me in the right direction for the requirements for adjusting my fuel settings when running a return style fuel system?
2006 4.6l 3v out of mustang gt.
I have an intank aftermarket pump run to a regulator which returns to the tank and feeds the stock fuel rails.
Only mods are Airaid 100mm CAI, Ford Performance M-9593-LU24A injectors.
Fuel system is controlled by a relay that is energized when the key is turned to run/start.
No FPDM, no EVAP, only front O2 sensors are being used.
In my tune so far I have disabled adaptive fuel voltage, I have also modified my MAF for the CAI, as well as adjusted my injector control settings for my specific injectors, Pats is disabled, and rear O2 sensors are set to none.
Am I missing anything that I need to adjust when using a return style stand alone system? I seem to get a lot of fuel when first trying to start it and I think it may be flooding my engine causing a no start.
Thanks D
