1 Attachment(s)
RPM Limit at 3500 RPM
I recently installed a 274 cam in a 2015 Challenger RT Plus. Been working with Josh at HHP. The issue that's going on is the car will run great on the first drive cycle only after i install any tune Josh or Diablo has sent. When shutting the car off and then back on again there is a rev limiter at 3500. Also the cruise control stops working. Ran a scan and the Throttle Torque Source goes from "PEDAL to "RPM LIMIT". The car will remain with the limiter until i load a tune again. Works on first drive cycle and then back to limiter after firing back up.
HELP!!! No one has any idea WTH is going on!!!! I know Josh is trying his hardest but he is even a stumped.
I've attached the scan for review
Attachment 110454
