aem 30-0310 x weird problem afr reads lambda and lambda reads afr
as i said in the tittle my new 30-0310x setup as a serial adapter is reading oposite values.
afr is reading 1.0 and lambda is reading 14.7
i double checked my wiring and even tried a different adapter but it seems to be something in hp tuners that i just cant adjust transforming the values makes it worse my afr goes to 140.70 if i try to adjust it and my lambda goes way out of wack aswell its as if the inputs were wired incorrectly in the module for the wideband or hp tuners doesnt support this model yet
