Desired Airmass Initialization Switch
Curious of a better description of what this switch actually does. I've seen it on and off on several different tunes from ford control pack to roush calibrations along with the air load value being set low to some set as high as 3.0 or more. I've thought that it used desired airmass as a average air flow calculation mixed with the MAF sensor. Where as without it being turned off was similar to the gm MAF only type of tune?
What I'm chasing is a sloppy load and calculated map signal as my car gets into higher boost and was curious if setting the desired airmass initialization to ON would help clean up the signal as in my thought was it blended the two air models to average the dynamic airflow? Aside from a maf screen which i'm leary to use i'd like to find a way to clean up the load and calculated map signals. Anybody got any tips
