2 Attachment(s)
Drivers O2 sensor erratic? 2 bar SD 5.3 Turbo
Gents - Details of setup are below. Current tune and log are attached. I am trying to get the idle and PT dialed in close on narrowbands alone. Drivers O2 goes nuts. ** I have checked for exhaust leaks, I have swapped O2's from side to side, I have pulled plugs. The behavior stays consistent on drivers side regardless of sensor change. Appreciate review of my tune and log, and any guidance.
5.3
LJMS turbo cam
S475 turbo
Boost ref FPR set at 58psi base
65lb Deatschwerks injectors (Closer to 75 @ 58psi)
4L85E
Circle D converter
