Wheel speed sensor woes!
During normal driving while scanning the front wheel speed sensors, they will intermetinly go to 0 mph to whatever speed the car is actually moving at. This is both sensors at the same time everytime. I also get a random "low trac" light when at a dead stop at stop lights. Probably time for a new EBCM or possibly something with HPTuners to correct this problem?
Can't fix ABS/Trac problems with the HPtuner.
Had a problem a while back with the sensors getting hot, then actually melting at the connection frmo the sensor to the main harness.
Ended up doing an ABS delete and removing these sensors after replacing them several times
