VCM Scanner missing parameters? for 2020+ F150 Ecoboost 3.5?
Hey Guys,
Long time listener, first time talker. I'm a cobb protuner and I'm wondering to calibrate my 2020 f150 3.5 ecoboost f150, however looking at VCM Scanner I'm guessing I'm only seeing OBD parameters because A LOT is missing.
Things I can't find that Cobb has for the Raptor and other ecoboost vehicles:
Requested Torque
Airflow limit src
Driver demand limit mode
throttle torque src (separate from torque src)
LSPI load limit/actual/desired
knock count for cylinders 1-6 (one parameter per cylinder)
Ignition corrections for cylinders 1-6 (one parameter per cylinder)
My truck is still factory calibration, I'm assuming what I'm seeing in VCM scanner is only OBD and after flashing the truck with a map, I'll gain access to the other parameters I'm missing (DMR)? Or is there something else I need to do to get the parameters I'm missing?
