have access to a 2013 5.0 flex fuel f-150 when you get that far
any feed back on the '05 focus 2.0 duratec with a manual?
Did you send in a read?
i currently have no means of powering up the ecu to do so, i have an ecu and wire harness from the focus. it is going into a custom application. The biggest feature to me is the ability to "turn off" the pats system as well as some other functions that are no longer needed for my build. the engine side of the spectrum will remain fairly stock for now. I have an ecu to donate and mail to you tho...
Eric
Any chance on 2009/2010 Ford Focus RS 2.5 turbo
Phil
Any idea what PCM they utilize?
They are a BOSCH unit, SCT currently supports them.
I can get you a read from a 2010 Focus RS Euro spec car also!
Just PM me if you'd like it.
--Christian
I have a Morgan Roadster 2009 which comes with a 2007 3.0L Ford V6.
The ECU is LBO-A56 TVX0 which is the same as in the 2005 Escape.
Will the latest software be able to read this, and if so could you easily add support?
hey eric... ive got a 2010 fusion sel id LOVE to be able to tune. (hate the way the trans shifts from factory)
i tried to read it with the 2.5 beta and i cant get it to read.
any thoughts?
says something along the lines of fx7 failed during active session of somthing like that...
Trying to read a 2008 Ford Expedition, Having issues just syncing up. Running the latest version 2.24.578. It gets all the way to Preparing Entire VCM, then goes onto reading VCM and errors out. VCM Read Failed at loc: 0 Error: Timed OUT.
Eric,
Any plans to tackle the 2014 Fusion with the 1.5l? The transmission logic and torque management are horrible on this vehicle.
Tried to hook into my friends 2012 Focus SE, i could scan and read parameters, but it wouldn't let me do a read entire in the editor, Kept getting an error. Am I missing something here?
I don't Bill, sorry. It's got that goofy auto controlled manual trans in it, And has been acting a lil goofy lately. We thought we'd hook up and see if there was anything we could adjust. Its no biggie so I wouldn't worry about pursuing support on it. Unless you guys want a file for future support.....I can dig into more?
If its a ford pcm we support(I think we support about a dozen controllers for them) I can have you read it with 2.25 but you'd likely need to go through each and every controller until you find the correct one(if you don't know what pcm it utilizes).
