1 Attachment(s)
Fuel: Power Enrichment (Driver Demand)
Fuel Power Enrichment "Driver Demand" chart:
I can only assume this exists to compensate for the slow-ass fuel enrichment via the Lambda chart, to prevent ping and retard, but it's not any faster, so why does it exist? Plus the enrichment doesn't follow the chart so it I really don't see the point.
The chart columns are RPM, fine. The rows are Torque, three rows; 80, 90 & 100%. Ok, 80% of what? My 885 max "Internal Torque", 80% load? It can't be 80% of my of my actual max because that varies. I'd assume the 885 Internal, but I'm unlikely to hit 80% so again pointless.
Oem is 1.00 in all cells. Why, I don't know.
The second example pix seems to work?
The third example kills it.
If I set the 80% x 3500rpm to anything other than 1.00, it'll make 80% x 3500 AND everything below it that value. In this case .922, so idle, cruising at 25 or 60, doesn't matter. .922.
So what is this chart really?
Attachment 125891
