Ford 6.7 Custom PID For EGT
Does anyone know how I could add a custom PID to read EGT using the EGRT11V sensor location?
I'd like to be able to monitor EGT using the EGRT11V PID. Using one of the factory EGT sensors from the exhaust relocated to EGRT11V sensor location.
I've done this with Torque Pro. Below is what I put into the Torque Pro app to monitor EGT reusing the EGRT11V sensor location. Torque Pro doesn't use the normal order of operations to solve equations, that's why there's so many parenthesis. I'm thinking I could rewrite this equation to use a standard order of operations and get rid of the hex to decimal conversion in VCM Scanner. But how do I locate EGRT11V or PID 22055E in VCM Scanner?
PID: 22055E
MIN 0
MAX 2000
scale x1
Unit C
(0.0004*(((1164.26*(((256*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285)))*((1164.26*(((256*A)+B)* 0.00097285))/(4.98-(((256*A)+B)*0.00097285)))))+(1.107*((1164.26*(((2 56*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285))))-237.33
