1 Attachment(s)
Bryton cycling tracker date shows year 2000 from epoch time instead of 2020 .fit file
Hi, Not sure if anyone else has come across this before. I am trying to get RR to read my data file correctly for the date and time. I have a Bryton rider 15 cycling computer as a data tracker. RR reads the data file which is .fit format, I believe it is the same a Garmin. All data seems to be fine apart from the date and time. For a data file recorded this year it displays the date as year 2000, the month and day are wrong also. Attachment 99679 I have attached a small sample file, rename it to .zip from .txt then extract to view it. It contains 2 files. one is the .fit file from the device, the other is a GPX export of the same file for comparison. The main reason I wish to use the .fit file is because it also has recorded speed. not a huge problem but would be nice if I could use just 1 file access all of the data.
it looks like a problem with RR reading the epoch time from the .fit file. when I upload to strava it appears correctly. The gpx is exported from strava and has the correct date and time, it is readable as a text file, but not recorded speed as mentioned.
Does anyone have an idea?
Can the Devs take a look and see if it is fixable?
Does the .fit file from a Garmin device have the same issue? I don't have a garmin file to test with.
Thanks in advance for any help.
