Return Style System with ID1300 - WOT Fueling WAY OFF
So I am using ID data for the ID1300x2 that I have (I realize there is now newer data, but its not that much difference).
I have a dual 450lph Fore pump, 10an feed, 8an return, Aeromotive 1000 regulator, Fore rails, 1300x2 injectors.
My WOT area of my VE table is down in the low 90's at 19psi of boost on my 426ci 4.5L whipple setup, something is very wrong with the fueling. I am getting way more fuel than the ECM thinks I am.
Anyone else experience this? The low VE is putting me in strangly low aircharge spots in the timing tables, which causes me a headache on the dyno.
Vacuum multiplier is all 1's
Data is copy and paste in the injector tables from ID
I will post the tune a little later, just wanted other's feedback. WOT I am around 10-11ms injector timing, .78 lambda on MS109.
