I am going to change my gears from 3:23 to 3:73. This might be a dumb question but the only thing I see I need to change is the gear ratio in speedo programming. Is there more than that or am I all good. Thanks
Under the edit tab, use the gear tire ratio calculator.
Plug in your new gear ratio and current tire size (it'll be the same), then make sure the auto scale transmission settings box is checked. That way it will move your shift points around for you to make the change smooth.
Thanks I was hoping it was that easy. Where is the auto scale transmission settings box?
The Autoscale is in the same Tire/Gear Ratio Wizard. You will see it when you open up the Wizard.
