PE mode doesn't enable at defined MAP enable setting
E38
Main OS 12656198
2014 LS3 Camaro
Speed Density
Under Fuel > Power Enrich > Enable, I have MAP set to 85 kPa. When I data log, I'll see kPa go above 85 and power enrich doesn't kick in, and the ECM is still commanding stoich. This typically happens when pulling up a hill, mid throttle, low RPM, high gear. PE will eventually kick in if you keep depressing throttle, but there is still a point where the MAP reading passes the enable PE MAP setting. Can anyone explain why?
Scanner: https://imgur.com/a/C7xFr2Q
Editor: https://imgur.com/LxnDkSB
https://imgur.com/mgbnsZ3
