8L90 - removed tcase and made 2wd, no speed reading now
I'll try and keep this brief.
Building a desert Bronco, 2wd Ibeam truck with an L86 and 8L90. Truck has been tuned and running well until i removed the transfer case. I removed it and added the fixed yoke from a Camaro to gain much needed driveshaft length and better angles. No need for 4wd anymore anyway.
Yesterday once i added the new shaft and drove the truck but it's in limp mode and not registering speed any longer.
My tuner doesn't know what to do and i don't get why the only speed sensor would be in the tcase and not the transmission. It shifts fine, just no power any longer which seems to indicate limp mode. Only code is P17D4.
Is there a specific 2wd 8L90 TCM tune that will then pick up the transmission speed sensors?
