05 6.0L PSD and PATS
Is there any way to disable PATS on a 05 PSD. I have a friend who has been fighting a starting issue, everything has been replaced (hpop, branch tubes, dummy plugs, ecm, etc). I wanted to try flashing in a test file to see if it helps him out.
Sam
It's not supported as of yet.
As far as I know those trucks does not have PATS, or at least I've swapped ecms ant they start right up, tell us more about the problem, maybe I can help you.
I'm 99% positive these trucks do not have PATS.
Only the excursions have it the trucks do not
you have air in the HP oil system and maybe in the fuel.
monitor your icp when cranking, 500psi minimum for the ficm to start firing the injectors, if you have that you can actually hear a change when cranking if the ficm is actually firing the injectors even if there isnt fuel. does it smoke at all when cranking? How long are your crank times?
