2 Attachment(s)
13 Mustang 6r80 Trans Tuning w converter
Hello,
Customer car came in for a trans tune, engine tune was done elsewhere, car is a 5.0 with a centrifical blower and a Circle D converter. Car had major shift flare and soft shifts with it sometimes going into "tip out limit" and having to pull over and shut off the car and restart. Trans tune was completely stock. Ive played with shift points, pressures, adaptives and the trans just doesnt seem happy. Log posted, had to increase the oncoming and offgoing pressures dramatically to get rid of the flare. When slowing down car clunks and bangs when its downshifting. I did a quick WOT 2-3 gear change at the end of log and it revs much higher than I want it too, should I just back down the RPM and MPH? I did disable shift anticipation earlier to try and help some of the part throttlel shifting (not sure if that effects it but I am open to turning this back on). Any tips or info is greatly appreciated. Ive researched the heck out of this the past few days, just want this right. Car has had blower for a while, trans was tune was stock then, shifting problems came about when the converter was changed.. Engine tune is not my work, I know the fuel trims are horrible, I will discuss that with the customer once I get this trans ironed out. Log and tune attached, Thanks
Attachment 93847
Attachment 93848
